I appreciate the feedback but there was no other way this could have been done and I did pilot each screw and have countersunk also. From the looks of it, it's improved our situation by 80%. Time will tell if it's short lived or not.I hope that you properly pilot drilled and countersunk for all the screws, if not driving the screws could result in the MDF splitting or delaminating, especially if you have screwed into the edges. Secondly, all your risers are plywood, and you have screwed into the edges of these plywood components. Apart from the fact that screwing into the edges of plywood does not give the strongest of connections (you should always screw into the faces of plywood sheets) this also can lead to the plywood delaminating over time
So I as a joiner I simply cannot agree that you've done a good job and I would caution anyone wishing to follow your example that they will probably doing a lot more harm than good, and that they might potentially exacerbate the flaws in their stairs. So instead if fixing it, you bodged it
You are wrong. The solution is to inject glue into the joints from below as I stated earlier. Having done this a number of times I know it worksI appreciate the feedback but there was no other way this could have been done...
I fear that screws will work looseYou are wrong. The solution is to inject glue into the joints from below as I stated earlier. Having done this a number of times I know it works
Thank you for the advice. Is there a technique to apply PU Glue from above rather than below? I can only really access the top 4 steps from below. Given the feedback, I'm happy to give the PU Glue a go as well
Thank you. Coincidentally that's the same glue I just went and bought. The last bit that I'm not quite sure of, is the mention of drilling at an 'angle'? My understanding was that I'd be drilling through the tread and into the top of the riser, where the tread is rebated to accept the riser.You can get PU glue in a cartridge gun form which will allow you to "inject" it. I guess you may be able to drill some suitably sized holes from above and inject the PU. You can practice on the accessible treads to ensure that you are drilling at the correct angle.
Evo-Stik Polyurethane Wood Adhesive 310ml - Screwfix
Order online at Screwfix.com. Sets in just 5 minutes for a waterproof, maximum strength bond. Can be sanded or painted. Suitable for interior and exterior use. FREE next day delivery available, free collection in 1 minute.www.screwfix.com
Cheaper versions are available.
Ideally, you would mist the hole with water, but that might not be possible. The water acts as a catalyst to speed up curing.
As it cures, the foam expands to fill (small) gaps.
As @JobAndKnock says, if you get it on your hands, you will end up with black stains.
Any excess foaming can be scraped and sanded back.
I used it (pu glue) a few months ago to deal with stair banisters that were rattling around where they are rebated into the treads. Previous decorators had simply used caulk, which had cracked. The PU glue worked well. With a couple of the bannisters I had to drill down so that I could be sure that the glue had successfully got in to the middle of the rebate.
It isn't rebated - the underside of the treads are grooved to accept the top edges of the risers.My understanding was that I'd be drilling through the tread and into the top of the riser, where the tread is rebated to accept the riser.
AgreedI normally buy PU glue in bottles but in this case the gun version is better suited.
