My mate has the same problem. Either wash up in cold water or boil a kettle!
How many bowls of water will it take to repay say 1000 quid to reposition a boiler
0.0000001pAdd the gas costs of heating a pipeful of water ( the pipe between combi and tap ) and then that pipe cooling down when the tap is turned off and the boiler shuts down.
it is more than just one bowlful. Probably several each and every day.
Do plumbers ( AKA heating engineers ) take account of wasted water when "designing" a system. After all they will not have to pay the running costs of the system they create.
When planning the plumbing for my cottage waste of water was a concern due to very long pipe runs. Solved with two hot water cylinders, one in kitchen and one in the bath room. I was lucky in that the rooms are large and space was available.
Approx 0.071kWh which at about 10p per kWh = approx 0.7p0.0000001p
10 metres of 15mm pipe holds 1.4 litres of water im sure you will work it out to see the true cost
what temps did you work it out at starting and finishing ?Approx 0.071kWh which at about 10p per kWh = approx 0.7p
And since it is a combi there are the unavoidable costs incurred every time the boiler fires up in response to a hot tap being turned on. Heating the mass of the heat exchanger before any heat reaches the water flowing through that heat exchanger. When the tap is turned off the heat exchanger cools down with most of that heat going out of the flue in the post-purge.
so you use every bit of water that you heat and none goes to waste by cooling down sitting there stored not being used .Which is where having an open vented system, with a hw cylinder wins everytime. Less gas wastage, less water wasted and usually the hw will appear at the tap quicker with greater flow rate.
By calculation, and assuming 85% combi efficiency, the dT = 37C, (0.071*0.85*860/1.4) so maybe 20C/57C starting/finishing?.what temps did you work it out at starting and finishing ?
Start 10°, end 60°what temps did you work it out at starting and finishing ?
