We're having the garden landscaped at the moment and as it faces south west, we get a lot of sun through the kitchen/patio doors...although not when this pic was taken:
While we have internal blinds, the heat gain/glare is still quite annoying so I'm looking at a number of options to shade the patio doors outside that might also make the patio comfortable for our kids on hot days. The kitchen window is less of an issue. The sliding doors are more of a problem even with solar-reflective glass.
I'm considering a sail shade I think we'll need 150x150mm timbers or 100mmx100mm steels sunk relatively deep (1:2 ratio above:below ground) to ensure we can put decent tension into the sail and avoid sagging. Getting a proper sail (i.e. not a £100 one from Amazon) along with the aforementioned hardware bumps this solution up in cost further.
Any guide on how best to spec this? Is there an alternative solution that you'd recommend instead?
I have 2x cantilever parasols but the weight (plastic, filled with water each year) now all leak, they take up quite a lot of floor space and sit too low to properly shade the doors so I'd prefer not to use them. Has anyone used a wall-mounted parasol? Any good?
