Hi
I have moved to a different home which has Vaillant Echo tech plus 418 boiler installed with open vented cylinder and a central heating system.
The thermostat on the cylinder is set to 60C and the boiler has two radial dials in front to control the flow temperature, both of which are set to 65C so that it can heat up water to 60C and heat demand should stop.
But boiler is doing short cycling when there's only hot water cylinder needs heating up and no demand for central heating.
I have tried turning the thermostat temperature down from 60C to 55C but making no difference.
Upon going through several posts and documents, I am completely confused as to the correct settings I should have before trying to diagnose the short cycling issue.
Would someone be able to suggest some figures on below questions:
1) What should be the thermostat temperature set at the hot water cylinder at max. (PS: I am OK with 60C to keep legionella bacteria out.
2) What should be the flow temperature settings on the boiler for hot water e.g. +5C to whatever thermostat on cylinder is set to or same as thermostat or lower than the thermostat
3) What is the ideal flow temperature settings on the boiler for central heating
4) Anything obvious I can do to fix the short cycling or is it usual for ecotech plus 418 model to short cycle when water in the cylinder has heated up enough?
In my previous house, I had megaflow and boilder always shutdown as soon as the desired water temperture is reached.
