Old gas meter leaking (edited)
28 Jul 2023
Checking the old gas meter it seem the pressure point knob has bubbles coming out, put some fairy liquid on it ... is location where brass point screw in to white plastic meter.
Easy fix for plumber? Is it new meter thing or common thing easy fix?
Thanx !
No, has to be a gas safe registered engineer or your emergency service provider/energy supplier. Turn off the supply at the emergency control valve, if the meter is internal do no operate any electrical switches on or off and ventilate the property, do not smoke or operate any naked flames, sparks etc.
Turn you gas supply off at the emergency control and call 0800 111999 they will come and replace the meter for free, do it now not tomorrow
Do they still swap meters Ian? I was told by Cadent engineer (iirc) they don’t really do it much anymore, or they have to obtain permission, something to do with assets?
Am I right in thinking that the escaping gas will sink to the floor, and accumulate in voids or the lowest part of the building?
yes it is complicated these days depending on the supplier but you have to contact them first and they will start the ball rolling
Yes thankx have booked, .... is part replacement ? Or tightening, maybe last time not tighten. Like this?
Or only new meter?
Is very small almost zero maybe tighten thing?
Or only new meter?
If it’s the barrel, then might have to be replaced, if it’s the screw new ones are available.
ffs just call the esp out on number that has been put up its free and they are there in 1 hour unless this is a windup post
Unless the Poster wants his house to go KABOOOM!
