I will install a marine ply base, which will be screwed into the joists and noggins shown in the photo, upon which I will (with some assistance!) mount the shower tray. Should I also glue the marine ply down, or will screws suffice?
The manufacturers recommend mounting the tray on a weak sand/cement mix, which I will use. Do I need to prime the marine ply before applying the sand/cement mix? I've read conflicting advice about this, and if I should do this, what primer is best to use?
Also, do I need to seal the gaps around the edge of the marine ply base, where it sits in the 'gap', and if so, with what?
