D
Deleted member 267285
Sorry, missed that bit!Every hot water tap in the house!
Not necessarily, what I mentioned in post #14. The cold water storage cistern need to be checked it’s got water in it and filling back up correctly. The gate valve might be not fully open, or closed but not fully and letting by. All basic stuff for an experienced plumber.So something blocking the hot water tank output?
For background, if you open a tap till you get hot water, then close it, and then open it again a few minutes later, I'd guess you get water straight away. How long do you have to leave it for the problem to recur?Only moved in a few days ago - previous owners moved to Spain to retire..
Agreed, it seems unlikely there's a blockage so solid it can't be cleared by mains pressure or something, and even if there were, I can't see how that would produce the symptoms described.You need a Plumber, the Guy you've found is either not a Plumber, doesnt want the work, or is looking to sell you an expensive fix a bit further down the line. Your daughter has a very simple, tried and tested system, of which there are countless fitted throughout the Land.
It is simply a process of elimination to find out what the issue is, as said, start with checking the cold storage cistern has water in in, and the outlet isn't blocked. If that appears ok, I'd be looking at the outlet from the cylinder, to see if there is water there, if those prove ok, then the issue is in the pipework, and if blowing back with mains pressure doesn't solve the issue, then I'm afraid it will be floors up time to trace the pipework.
Do you know what the pipework is made of, e.g. copper, steel, plastic?
Does the Hot supply in the downstairs Loo work ok then, or what brings to to that conclusion?Whatever it is it seems to be after the junction with the downstairs loo. I guess he's looking there.
