Enforcer v11 sounds
29 Mar 2020
Hi.
I have installed enforcer v11 myself and everything is working as I wanted except:
1. How can I turn off any sounds on main panel? I have managed to turn off main sounder but it still makes little sound
Reason: I have remote keypad next to the door and I don't want to disclose where is main panel located in case of intrusion.
2. Remote keypad makes only one chime sound and then don't make any chime sounds. ( while main panel always make sound )
Thank you in advance.
Set volumes to zero in volume control you can turn off each one
If I set to 0's then there is no sound at all.
I would like to have:
Entry/exit sound on wireless keypad
Chime sound on wireless keypad
And no sound at all at the main panel
Reason:
I my point of view that's the main reason for wireless keypads. So you can hide main unit so intruder can't find it easily and break it. But because main unit makes sounds it makes no sense.
Disconnect the piezo sounder in the control panel.
To do this you need to open then panel and unplug piezo fly lead.
This is exactly what I was planned to do in worst case scenario. Im little bit surprised how company who is manufacturing alarm systems for so long haven't sorted it out in so many years.
I don't get it how they think user should use this system. Just place whole main unit next to the door?
It's an on board control panel not a blank end station,therefore it will have a speaker installed.
That’s the idea ….
