I'm trying to connect 3/4" copper to 22mm copper in an old house. However it appears that the 3/4" is actually slightly smaller (measured at 21.1mm) than it normally is. This means I've been unable to use the special 3/4 to 22mm compression fittings as the olive is just too loose. Similarly I have a 3/4 to 22mm solder fitting, but that's too loose for the solder as well.
Anybody come across this situation and have any tricks?
Thanks!
Thanks!
