I have a submain in the annex which runs off an appropriately sized MCB on a RCB board in the house.
The annex has it's own 3 way RCD board which again has been sized appropriately: 32amp MCB for a small ring circuit constructed from 2.5mm T&E cable and a 6amp MCB for a lighting circuit run off 1.5mm T&E cable. Everything is working fine.
Q. I can understand that if there was a fault/overload on any circuits within the Annex, the associated MCB/RCD will trip. Are there any situations (other than a fault on the cable between the house and annex) where the MCB/RCD in the hosue would trip?
Thanks in advance.
Thanks in advance.
