I'm at the stage of my extension where I need to lay the floor insulation before doing the screed.
I currently have a concrete slab, which will have a DPM, then 100mm of PIR. The issue I have is that when I did the concrete slab, I didn't manage to get the surface completely flat. I could do with filling any voids under each insulation board so that it is fully supported.
I was originally planning on putting a thin layer of sand down, but because I don't want to increase the floor level any more, this would need to be extremely thin in places, and compacting this with a wacker onto a concrete slab might be a bit aggressive.
I was wondering if it is possible to stick each insulation board down with expanding foam adhesive, as I have done with the roof. This would fill any gaps and be much easier for me to do, but will this provide suitable support for the floor? I would think as long as I apply a decent amount then this should work, but can anyone suggest a reason why this is a bad idea?
Cheers.
Cheers.
