No certificates of any kind are required for selling a house.we are selling our house and needed a gas safety certificate.
Sling the gas hob out and fit the cheapest electric one instead.The gas Safe chap said for the gas hob to pass, we would need to fit a trickle vent
The buyers asked for one, not an unreasonable request, IMHONo certificates of any kind are required for selling a house.
Pass what exactly? You’ve stated room >10 m3 and an openable window, does the window open to fresh air?I should explain that we are selling our house and needed a gas safety certificate. The gas Safe chap said for the gas hob to pass, we would need to fit a trickle vent in the upvc window frame
They’re not a pass/fail.Hi, to pass the gas safety check.
OK, I suppose he ment we needed to fit a vent in order for him to issue a certificate. He hasn't given us one anyway, as some expired smoke alarms need replacing first.They’re not a pass/fail.
No extraction to the outside. So are you saying that a kitchen larger than 10m3 with a window opening to the outside, in a house older than 2008 isn't enough, and the table in my op is incorrect?If you have an extract fan ducted to outside you dont need any further vents.
what you have is perfectly safe and well within the regs whoever told you otherwise is struggling with a basic exam question . Do not use him againNo extraction to the outside. So are you saying that a kitchen larger than 10m3 with a window opening to the outside, in a house older than 2008 isn't enough, and the table in my op is incorrect?
Thank youwhat you have is perfectly safe and well within the regs whoever told you otherwise is struggling with a basic exam question . Do not use him again
