Ventilation for gas hob
27 Oct 2023
Hi, could a gas Safe person advise me if this table (or the first row re gas hobs) is up to date please? Our house was built pre-2008, and is in England.
Many thanks
Thanks. Yes, it's at least 20m3, there's a window to the outside, and patio doors (although they lead into a conservatory)
I was concerned because I also saw this (attached) but maybe the new regs only apply to new builds?
I should explain that we are selling our house and needed a gas safety certificate. The gas Safe chap said for the gas hob to pass, we would need to fit a trickle vent in the upvc window frame, because the patio doors open into a conservatory. Seemed a bit OTT as the kitchen is naturally drafty due to all the pipe work going through the floorboards under the sink!
No certificates of any kind are required for selling a house.
Sling the gas hob out and fit the cheapest electric one instead.
The buyers asked for one, not an unreasonable request, IMHO
It would be cheaper to refuse the trickle vent, if the regulations don't require it
Pass what exactly? You’ve stated room >10 m3 and an openable window, does the window open to fresh air?
Hi, to pass the gas safety check. Yes the room is well over 10m3, and the window opens to fresh air.
At the time I didn't know the regs, so didn't challenge it. I will now, but wanted people who have the knowledge to confirm what I'd found online first. I wouldn't normally assume to know more than a qualified gas safe fitter.
If you have an extract fan ducted to outside you dont need any further vents.
No extraction to the outside. So are you saying that a kitchen larger than 10m3 with a window opening to the outside, in a house older than 2008 isn't enough, and the table in my op is incorrect?
what you have is perfectly safe and well within the regs whoever told you otherwise is struggling with a basic exam question . Do not use him again
