- Joined
- 28 Feb 2023
- Messages
- 6
- Reaction score
- 1
- Country
Hi I have been wiring in some new plugs and a dimmer switch to our bedroom.
The original single rocker switch has more going on behind it than I expected, and I want to sense-check that I am doing it right. In particular I want to check I'm earthing it correctly.
Here is the orignal wiring on the rocker switch....
and here is the wiring with switch removed....
My understanding is the singular live wire is providing the input voltage as it was attached to L on the rocker switch. The double live wire is the "switched live" as it was in L1 on the switch. (It is not marked or taped, but I think it must be the switched live?)
So if i put single live into Com on the dimmer, and the double ended live into L1 on the dimmer this should be correct for the live wires. My problem then is understanding how to safely earth the metal faceplate. Do i free up all the earth cables and attach them to the earthing connection on the socket?
Any advice would be much appreciated, and apologies in advance if what ive written is unclear!
