What is the quickest way to reduce water damage if a CH pipe burst or radiator pipe started leaking and you couldent stop it?
Had a scare recently and want to know for future, as i understand, water will slow and eventually stop leaking when the pressure inside a combi boiler drops, is that true?
If so would putting a bucket under the offending rad and undoing the nut from the wall to the valve work quickly or would water just keep coming and coming non stop?
If i pull the combi boiler pressure relief valve will that help?
