I've been using various online calculators for calculating u values for wall insulation, however they seem to vary considerably and make massive assumptions.
I need to decide how thick insulated plasterboard i install into some bedrooms - my property is a victorian semi detached, 2x brick skin without a cavity. The ceilings are higher than usual - 2.7m and there are large (sometimes bay) windows of at least 1.5m square, there is enough insulation in the loft above.
Is 62mm celotex/kingspan sufficient? I will be fixing it via batons, as there is no render externally and i dont want to remove all the plaster as its in good nic.
