Hi can anyone help the 15mm copper tube overflow pipe o the outside of house is constantly dripping .checked the combi boiler and it's 2.5 bar pressure. Tried emptying some water out of system but still 2.5 bar
Used to have a keyed filling valve.but after it stopped working. Had a keyless valve fitted about 2 years ago with a blue lever could this be .not turning off properly
It is ,if you know what to do.
Your PRV may also need attention, If it's continually dripping ,even when boiler is off ,and system pressure is down to 1.5 bar.
Had to change a plate Hex in one of those recently with that fault.
I proved it by isolating cold inlet to boiler, pressure remained stable, shortly after turning cold back on again, pressure would increase, 1st time I've seen that on a WB.
