- Joined
- 17 Nov 2023
- Messages
- 3
- Reaction score
- 0
- Country
I live in a 1920’s semi-detached house with solid walls.
As we’ve moved into winter/wetter weather I’ve noticed a tide line beginning to appear on part of the hallway wall leading to the stairs. The other half of the hallway closer to the front door does not have this issue.
We have also recently realised that the inside of the cupboard under the stairs is very wet - the walls have visible moisture and are going mouldy (brick floors under the carpet).
This entire wall is on the detached side of the house. There looks to be an injected DPC externally and it looks as though the internal hall wall has been replastered to a height of approximately 1m previously.
I am unsure if there is a DPM under the laminate flooring and I am unable to remove the skirting board to check if the plaster reaches the floor.
I have been advised that this is rising damp and the DPC has failed.
Is this correct?
Is this correct?
