Newly fitted light switches trip the breaker. (Ed.)
This is a pic of the wiring. I’ve just capped them off for now. The cable will obviously be cut shorter eventually.
Grab a meter, and check from that (blue) wire to the brown wire... and report back here what you get. Then from the earth to the (brown) wire.
It would be good to answer the early question of how did you wire the light?
Are there 2 cables?
Did you connect both browns together into the fitting?
Did you connect both blues together into the fitting?
Yes, this is common where a fitting that has feed(s) and switch wires present at the fitting and has been wired with the reds/browns connected to each other and the blacks/blues connected to each other. This causes the fitting to illuminate permanently with the switch off and trip the circuit protective device when switch is turned on.
Hi Adam, in terms of the connection to the fitting. There are two brown wires in one hole, two blue in another and two earths in the third hole. They are doubled up as the lamp also connects to another identical lamp further along the wall
Are there 2 cables?
Yes that sounds right in terms of how I wired the light fitting.
So here’s the wiring inside the light fitting. Left - blue x2 middle earth x2 right - brown x2.
You say the second cable goes to the other light; Is that correct?
Both - correct that that is what you said and correct that it actually does.
Hi, I have two wall lights in a bedroom. I am currently fitting the switches. There are to be two switches one under each light. When I began to fit the first switch, I connected the wires to the switch unit and the lights came on. But when I go to switch off the light switch it trips the fuse in the consumer unit. Any ideas why this happens? Could it be because the second switch isn’t connected yet? Thanks .
What do you want the second switch to do?
Are there perhaps two associated switches, which you are fitting, or replacing? Is this what is called a two-way switched system? Two switches, either of which can turn on or off, one or more lights?
