- Joined
- 30 Nov 2023
- Messages
- 12
- Reaction score
- 0
- Country
I may be a granny and I am definitely now goosed and really do now wish I did not have a primatic cylinder tank but I do. The house I bought is ex council and the system had always worked well with the exception of air locks every time it needed drained for any repairs.
I had a new boiler installed 7 years ago, and the plumbers were old skool and convinced me that easiest and most affordable way was to go like for like and not bother with a combi. I took them at their word, replaced boiler and nearly all radiators and all was well...until a couple of weeks ago. I discovered a leak (well, I discovered a hole in my kitchen ceiling at 5am and then the leak!) which was below the floorboards upstairs in the airing cupboard where the hot water tank is housed. Needless to say I was onto my 3rd plumber before I could get someone familiar with the old system and with the time to drain and repair. They drained down system (from downstairs radiator), cut and replaced the leaking pipe (joint at manifold) and then refilled. Heating is all working great but I have issues with hot water not heating very well.
I lost water pressure to the hot taps upstairs and I obviously had an airlock, so found time after a couple of days to push water back through via mixer tap and restored pressure. Excitedly ran a bath in 10 minutes (was 40 minutes after initial repair) only to have to fly in and out of it in record time as it was merely warm. The water is not brown, so I don't think there's a problem with bubble and appreciate the likelihood of silt/sludge upon refill. I have taken plumbers advice and cranked up the thermostat on the tank to full and have boiler on constantly as he thinks this will help -I don't think so though. Pipes from tank are hot, but tank itself is cold and water continues to be warm but not hot. Dreading the impact on bill for having boiler running constantly too
The repair was carried out under a package, so the plumber has fulfilled their part in fixing the leak. They also returned the next day as I was concerned about whistling and smell from boiler (bear in mind everything was working fine even with the leak, heating, hot water etc). He then realised a black pipe from what I believe to be the condensate trap wasn't in properly and then snapped the condensate pipe, but quickly replaced this. the noise has stopped but the smell is still there. He assures me it isn't gas (in fact, said he couldn't smell it but friends and family can) and I have a carbon monoxide detector that is showing no concern.
I have no spare cash, can't consider replacing everything and would be super grateful for any advice on easy steps I can do to try and regain hot water and long, lingering baths and any tips re the smell from boiler. Any help from anyone familiar with the joys and woes of primatic cylinders (and yes, it is definitely a primatic cylinder and is fed by gravity from cold water tank in loft, I know, I know) might just make this granny's christmas break a bit less stressful.
Thanks in advance and sorry for long post but read so many posts with lots of people asking "are you sure it's primatic" or just advising to "get rid" which really isn't an option right now.
