- Joined
- 27 Sep 2022
- Messages
- 304
- Reaction score
- 23
- Country
I have a Fan Coil unit in lounge and radiators in Bedrooms and Bathrooms. I also have a wired thermostat in Lounge with the boiler which is set to 19degC.
Issue - FCU never turns off, it keeps running, if boiler is firing, FCU will blow hot air but when Boiler trips and as water temperature cools down, FCU starts to blow cold air (which is counter productive in maintaining the Lounge temperature; I have to manually switch the FCU off and then turn back on when boiler fires again).
I know FCU works best at high water temperatures whereas I am running at a boiler flow temperature of 50DegC which works fine for radiators in the property (I have oversized rads).
Remedy - I was thinking if I put a pipe thermostat (like attached) on FCU flow pipe and set the Pipe thermostat to 36DegC so it turns off the FCU when return temperature falls below 36DegC.
Would this approach work for FCU in what I want to do or is there a better solution.
Thanks for taking time to read the posting.
