If, as seems to be the case, you're wanting to be pedantic, that statement is not strictly true. It would be 'correct' for a supply at (230 x √3) volts, which is about 398.37 V.That's correct for supply at 400V phase-phase, which wasn't specified.
Not sure what you're getting at. I was just saying the voltage is needed to calculate the current (OK I accept the forum is Electrics UK, but it might possibly be 230 volt).If, as seems to be the case, you're wanting to be pedantic, that statement is not strictly true. It would be 'correct' for a supply at (230 x √3) volts, which is about 398.37 V.
Fair enough. I thought you were saying that thee calculation using 230V )phase-neutral) was only correct if the supply was 400V phase-to-phase, which I took to bee a quibble about the numbers.,Not sure what you're getting at. I was just saying the voltage is needed to calculate the current
Again, fair enough, but I'm not sure that anywhere in the world has supplies with 230V phase-phase (i.e. about 133V phase-neutral), do they?(OK I accept the forum is Electrics UK, but it might possibly be 230 volt).
Agreed, as you say it's highly unlikely, but strange things happenbut I'm not sure that anywhere in the world has supplies with 230V phase-phase (i.e. about 133V phase-neutral), do they?
I can't argue with that, but the fact that that is 'highly unlikley' combined with the fact that (as you have observed) this is an "Electrics UK" forum, I really can't see that anyone reading this thread would think other than that what was being referred to was a ('standard' oin thee UK) 230/400V 3-phase supplyAgreed, as you say it's highly unlikely, but strange things happen![]()
OKI can't argue with that, but the fact that that is 'highly unlikley' combined with the fact that (as you have observed) this is an "Electrics UK" forum, I really can't see that anyone reading this thread would think other than that what was being referred to was a ('standard' oin thee UK) 230/400V 3-phase supply
+10%/-6%.Not sure what you're getting at. I was just saying the voltage is needed to calculate the current (OK I accept the forum is Electrics UK, but it might possibly be 230 volt).
It's irrelevant whether you say 400 volt 3-phase, 400/√3 1-phase or 230 volt 1-phase, 230*√3 3-phase, they're only nominal figures. I believe it changed from 415/240 volt to 400/230 to be same as the continent, but with a +-5% tolerance, so 415/240 which is within the range. Though nothing needed to change, last time I checked, mine was 239 volt.
Thanks, I wasn't sure about the %ages+10%/-6%.
