Danfoss TP5E replacement
13 Nov 2008
Avon
Looking to replace this old intermittent stat control.
Danfoss TP5E
I’m not local to it at present as it’s at my sisters, I’ve been looking for a installation guide to see how many wires there are but only found user manual.
Anybody know how many wires ?
My goal is to remove this from the wall & replace it with something newer but I was told need to know how many wires it has.
Can you advise how many wires & an easy to use replacement.
My sister only ever uses it in manual if that helps you advise a replacement
Looks like it’s a 2 wire - live and switched, so to replace like for like you’ll need similar. If you wanted different, depending on the setup, you could opt for wireless.
I since found that it’s 2 wire.
It also mentioned no earth or neutral so live & switched live mentioned above would sound correct.
So do I now just look for a 2 wire stat ?
So going by the member saying it’s 2 wire can I use the following stat & wiring also shown, please advise thanks .
I would say so, if you read the writing above it states a 2 wire. Might be better with digital though, as it might be more accurate, so a Siemens RDH100 or Honeywell DT92.
I had seen it mentioned 2 wire but didn’t see what the 2 wires were.
You mentioned live & switched live.
So does that mean the above is the same or not ?
Yes, it’s the same. Some reason, manufacturers tend to put N as the return/switch live.
