I need to join an existing engineered wood floor to a new one, same depth and make model but 2-3 years apart.
Old floor isn't on any underlay or if it is I can't see it. New floor has a DPM sheet and 3.6mm underlay sat on a concrete slab or at least it will be.
I bought a door threshold strip rather as it avoided needing to join the two pieces this but it doesn't fit below the door. Annoyingly the door is a pocket door which I have no idea how to get out. Even if I were to remove the architrave and door surrounds it doesn't look like it would come out which is v. annoying.
So all I can think of doing is around the threshold remove the insulation and figure a way to join the two sections together. would be simple enough I think if the both pieces were accessible but because the existing is on the floor already I can't think what to do.
Anyone have any experience of this? or better suggestions?
Thank you
Thank you
