Dimplex optimyst lamps/bulbs
6 May 2023
Hi all,
My partner has a dimplex optimyst fire which has 4 x 50w halogen lamps. I have read on this site that a couple of members contacted Dimplex to ask if they can be replaced by LEDs . The answer was that the 200 Watts is needed to make the mist rise.
However my later Dimplex optimyst has 5 x 1w LEDs and works fine.
I'm sure the technology is the same ( transducers are identical )
Any thoughts please
Heat rises. 200 Watts of wasted energy to make some water vapour rise up a chimney! People have certainly fitted lower wattage halogen lamps 35W for example from reading I did when we 'inherited' such a fire with our house purchase (I don't use it, having fixed some burnt out wiring internally).
NB Optimyst fires are typically 12V ac lamps. LEDs will need be the same (AC rated rather than DC) ... but may be presented with rather more than 12V ac as the transformer is under significantly lower load than designed for. A multimeter can check that with all lamps removed. Too high a voltage could shorten lamp life, potentially.
Thanks for that rodders53, I might just remove 2 lamps and see how it goes.
As regards my later fire with 5 x 1w LEDs, I delved a little deeper, literally, and found a small heating element down there adjacent to LED lamps.
I have emailed Dimplex asking what the wattage of this is.
I am running 2x halogen 35W (heat producing) and 2x LED bulbs (obviously producing no heat). Takes perhaps 20-30 mins longer for the full smoke effect that I used to have but works fine. Also lower wattage bulbs will help out with brittleness occurring on the lamp holders.
Hi all,
Any thoughts please
As a side issue,if your fire stops misting and you suspect the transducer before buying one stick it in a kettle descaler for half an hour, worked a treat for ours.
Moved into a house that had been empty for two years, no instructions for any equipment.
Came with Dimplex wall opti-myst fire installed.
Long story short, transducer replaced via Amazon, £15, set of 4 discs & tool about £6.
All working well and friends amazed at flame effect.
Liking advice here re alternative lamps. If power bills are humongous a change may be tried, but I like a quick smoke
