Yes it will work fine ,but don't expect the same pressure that your large pump delivers. You would probably get around 6 or 7 litres per minute flow from the booster.
What do you get now from kitchen hot tap ? Run it on full for one minute ,into a container, and measure how many litres are in the container.
RP75TU quietly boosts the water pressure across multiple outlets. Our most powerful range of pumps, the Right Pumps utilise centrifugal force to increase water pressure.
That's similar to one I used in my daughters flat for same problem .
Your pipe coming out of the top of the cylinder should angle upwards to prevent air locks .What's above cylinder ?.
If your not sure how to do this then a plumber would be your best call .
