Kitchen tap not hot enough (Ed.)
Yes it will work fine ,but don't expect the same pressure that your large pump delivers. You would probably get around 6 or 7 litres per minute flow from the booster.
What do you get now from kitchen hot tap ? Run it on full for one minute ,into a container, and measure how many litres are in the container.
can you link me exactly what I neeed to buy - its lots of them there
750 ml per hour, think you mean per minute ?
If I recall it's the SP2 that you need ,I will check.
It's the SP2B that you need
Could this pump be a solution ?
Appreciate your help
That's similar to one I used in my daughters flat for same problem .
Your pipe coming out of the top of the cylinder should angle upwards to prevent air locks .What's above cylinder ?.
If your not sure how to do this then a plumber would be your best call .
So I can buy that pump and I will replace it right ? - Above the cylinder is just storage shelf - lots of room.
