I'm after a bit of advice on my fireplace masonry
Anyone know what the part that has the two diagonals with the exposed steel reinforcing is called. Is it a type of lintel?
Looks like may be supporting the masonry above but I'm not sure and wanting to know if I can remove it in order to create a higher fireplace opening without being able to see the diagonals either side once I brick over the front facing brickwork....it was already damaged when I removed the outer facing brick work. So wondering if it would be safe to remove temporarily and replace with a suitable straight lintel or whatever would be required
any advice welcome
any advice welcome
