Laying Sheet Vinyl on to ceramic tiles
25 May 2017
We have a small downstairs toilet that is 1.1 x 1.3m. Currently we have ceramic tiles on the floor. It’s often used by muddy children and they are a nightmare when wet, it’s hard to sweep and mop, the grouting is coming up and several hairline cracks in them. I’m the next couple of years we will have the bathroom done but not now so I am looking for a quick and cheap fix. I know that it will be a botch job but I want to make the best of it.
- We have been given a roll of vinyl flooring that will fit.
- we have also been given some Volden Aquastop underlay to use if needed
- the toilet and basin have been laid on top of the tiles
Looking for any tips or advice??
- I have seen that filling in the grouting can help the shape not show through? What should I use to do that
- Do I need to use adhesive to stick the vinyl flooring to the tiles?
- Do I need underlay, if so would the Volden Aquastop underlay work?
- Any tips on cutting the flooring to fit in to corners, around toilet etc
- what should I use to seal where the flooring meets the wall/toilet etc?
Thanks, apols for the basic questions!
Decent underlay will gget it reasonably flat but the whole thing can look botched if as a first timer you cut round the toilet etc. Best to lift the pan and skirting so the vinyl goes under leaving a smooth edge. Cutting templates from cardboard to transfer can help otherwise. And take lots of measurements as the room wont be square.
Laying vinyl directly over uneven ceramics will cause the grout lines and cracks to telegraph through the surface very quickly. This 2024 thread caught my eye while searching subfloor fixes, and it's highly relevant for property owners looking to remedy slick, damaged tiles on a budget.
Stellmann Non-Slip Coatings solved our problem when our wet area flooring failed compliance here in Aus, providing a chemical micro-grip treatment that fixed the slipping hazard without demolition. Anyone considering a temporary vinyl overlay must use a self-levelling compound to patch the substrate first, or the new wear layer will distort and tear.
