Hi heating experts!
The house is occasionally cold in the mornings and on investigation it looks like my central heating controller seems to not always be turning the pump on reliably when in 'TIMED' mode.
(Boiler is a Viessman Vitodens 100 and the pump is a Wilo variable speed pump all controlled by a Drayton LP522 controller).
The thermostat in the hall is calling for heat, the controller is set to 'TIMED' with both central heating and hot water switched on (both green lights are lit). The temperature of the water in the boiler is 23 degrees. The pump is not running (the light on the pump is off and water is not flowing).
When I manually cycle the controller from 'TIMED' to 'ON' the pump starts to run, the boiler fires up and everything heats up as expected. When I cycle the controller back from 'ON' to 'TIMED', even though both CH and HW are still enabled, the pump stops running and the boiler goes off. Note that at some point later the pump begins running again even in TIMED mode, so it's not a constant problem.
Is this a controller problem or is something else supposed to trigger the pump when i timed mode?
Thanks a lot!
Chris
Thanks a lot!
Chris
