Hi
First time poster, apologies if I miss any details. I have just moved into a house with a pressurised hot water tank and a bronze pump to keep hot water flowing around the outlets.
I have noticed that the tank constantly fires the boiler for a few mins every 20/30 mins to keep it at temperature. My main question is, is this efficient..as even at 3am it fires to keep the water hot in the tank. There is no timer on this, just a timer for the bronze pump which I have set to not pump around while we are asleep.
The boiler is a greenstar and while it has seperate temperatures for the radiators (house is underfloor) and hot water, everything seems to be fed off the radiator temp meaning I can’t run the underfloor at a lower temp as the hot water won’t come up to min temp.
Hopefully this makes sense, any advice on this would be appreciated as a few plumbers don’t seem to have much of an answer on if this is the right setup and if it makes any sense..
Many thanks
P
Many thanks
P
