I have just bought a Ring Floodlight Cam and am hoping to install myself. I plan to fix to an external wall, drill a hole through to inside. On the inside is a plug socket (quite hidden in a cupboard so not easily accessed). Can I just purchase the following to wire it together, or should I be getting an electrician? Also what fuse should I use, is 5a ok?
www.kenable.co.uk
Power Cable UK Plug (5A Fused) to STRIPPED BARE ENDED 0.75mm Lead 2m Blacks
Fully moulded 3 pin UK plug fitted with a 5A fuse to a 3 core stripped bare end cable. Suitable for devices up to 5A the stripped bare ends are made from 0... [see below for full description]
