I am installing a floodlight ring cam, which I was installing with 2.5 cable to s plug through hole in wall from existing sky cable. How would I go about wiring a permanent switch from garage electrics. Ian
I would have thought that 2.5mm² cable may be way too big. I'll bet that thing only draws a fraction of an amp.
How you wire it inside the garage depends on what electrics you have in the garage.
