Fixing plasterboard to steel beam?
It's obviously a massive conspiracy, all these companies selling self drilling screws and their common usage across building sites around the world. It's a mystery how any engineering is ever done if a 3mm hole can't be made in a bit of steel.
This site is never short of sarcasm :LOL:
Drill bits are really hard work, need to go slow and use cutting compound. Honestly, just get the screw and an impact driver…no pilot hole needed.
Fixed my door frame with 100mm tektight screws, all went straight into 10mm steel.
I've been told from various tradesman that were doing other jobs in the property at the time they mechanically fix noggins however another said to just to knock them in and not attach to the steel.
Timber over time, can shrink - so they can in time become loose.
Thanks everyone for the response.
What were those that managed to screw through using the Tek screws beams made of wood?! I'm drilling with a small cobalt drill bit 3mm applying pressure not getting anywhere - web is iirc 7mm thick.
Decent brand Tek 4 screws with 8mm hex head will go into UBs easily without pilot holes.
You really shouldn't have this much trouble with a decent drill bit or a tek screw, but if drilling is getting you nowhere it'll be very quick and easy to Hilti gun some ply onto the flange and attach the plasterboard to it
We used the cobalt drill bits for piloting our tek screws. Absolute boon. I bought a full carton of (small mm?) drill bits, thinking there would be a high attrition rate. I used one bit and am still using it, lol.
I don't doubt it.. Unlike a DIYer, your long commercial experience will have conferred skill, toolset and expertise not available to the OP. Something is going wrong here, be it tools, material or technique..
If the OP keeps coming up short via the drilling route they may wish to spend a relatively small amount on hiring a Hilti gun and get the job done in 5 minutes. At some point the cost-benefit balance of time wasted will tip in favour of an alternative approach
I'd suggest starting with a bigger size pilot hole than 3mm. It's a bit weedy for that thickness, you've probably melted the tip. I find that drilling lube just slows things down, it makes the bit too slippy to get purchase (Ok in an engineering workshop etc.)
I just submerge the bit in a small pot of water every 30 seconds to keep it from overheating. I found the DeWalt extreme HSS bits very good for metal, I have a few and save them for 'best'
/nosarc.
