All I can say is that a lot of people seem to say (and believe) that - but perhaps you are the only one who is actually correct.Nope
If the earthing facility has been installed by the DNO, then yes, they have a duty to maintain it.My understanding is that if there is a DNO-supplied TN earth, then they are obliged to 'maintain' it (which, in the case of TN-S, often means changing it to TN-C-S) ??
If that's your supply coming into the box marked 415V, it doesn't look like SWA.try againView attachment 336664
I would describe as a wrap around P clip with a pinch bolt. I think it is copper or maybe brass?If that's your supply coming into the box marked 415V, it doesn't look like SWA.
It appears to have a copper strap round it.
As I said, that has always been my understanding, but it appears that if one has "many years of experience at the coal face" one 'knows' that it is not true!If the earthing facility has been installed by the DNO, then yes, they have a duty to maintain it.
I know of many cases in which DNOs have addressed thee issue of a TN-S earth having become inadequate by converting it to TN-C-S. I thought that that practice,which some people here have described that as a 'lazy' or 'cheapskate', was common?But they don't usually change the supply type.
That's obviously a bit different,since if it's TT, then the DNO have never provided an earth.Occasionally, IME, DNOs have upgraded TT supplies to TN-C-S on request, providing the infrastructure is suitable. Sometimes they have done this for free, other times for a small charge.
I see.Just experience at the coal face over many years
It's a bit more than double what most people seem to regard ads 'the maximum' for TN-S.However my first question remains Is Ze of 1.7ohm ok?
As I said, that has always been my I understanding. I'll leave you to argue we he who has had many years experience at the coal face.I have had many years of experience and the DNO have always sorted issues with their earth connections.
Interesting.I thought that it was a common occurrence and,as I said,have certainly seen a good few examples myself.IME, I have not experienced this. One TN-S supply I visited was replaced as the lead sheath had broken down under the ground.
If that happens, you cannot trust the integrity of the other conductors, hence the cable being abandoned and replaced.
