Hi I have an esp1 and noticed water leak from bottom of the case so cleaned condensate trap and double checked the connections in and out of it, anything else I can look at ?
i know the law, but having had my ticket for around 20 years and a technician grade plumber i like to think i am a bit more careful than a lot of people.Get a GSR engineer you shouldn't be even removing front cover.
Pressure wise I have just noticed it’s increasing very slightly, so today disconnected the filling loop to rule that out, and will monitor, heat exchanger swapped out a month from new around 6 years backDiverter valve, split in top of condensate anti. syphon trap, main heat exchanger ( but I hope not) is the boiler loosing pressure.
Thanks time to call an engineer thennew sump
Thanks I was actually thinking of lsx for the gasket on the access panel, but this was interesting
But now no leak after using lsx but trap filling up into sump and getting a soft thump when boiler fires, also around 1/4 l of water out of sump when trap removedIf its just the gasket on the sump cover that's gone then just get a new sump cover, no need to replace the whole sump. Lots available
Ideal Independent & Logic Clean Out Cover & Gasket (175954) for sale online | eBay UK
Find many great new & used options and get the best deals for Ideal Independent & Logic Clean Out Cover & Gasket (175954) at the best online prices at eBay UK! Free delivery for many products!www.ebay.co.uk
