Your shower will get it's hot water from the boiler ,and a little cold will be added to achieve your desired showering temperature.
I have to perfectly honest and say I hadn't, in all this time, appreciated the obvious, realistic point you make there. I, mistakenly, kind of saw the hot and the cold doing battle with each other with similar force and in similar quantities and any minor reduction in either supply having a significant effect. It's not uncommon to see reports of showers going cold or scalding hot coz someone flushed the loo or washed their hands in cold water. But the image you've created of it being mainly hot with just a smidge of cold to make smallish adjustments does rather put things into prespective. I have had almost no direct, practical experience of using half decent, recent combis and hope not to be disappointed when it eventually happens. I'm placing quite a bit of faith in a 32kw Vogue and its apparently respectable components within and realise it has it's detractors ... but they all seem to.
We shall see.
Thanks.
We shall see.
Thanks.
