Cable direct to switched fuse box ??
14 Oct 2023
Hi I'm thinking of putting aa hole in the chimney breast to put an extention through. So I can attach TV through it.
Can I just take the plug off the extention and attach the cable direct to the fused box .. instead of taking the plug and plugging into the socket on the other wall.
Sorry I meant the FCU which u can see in the pic. It doesn't serve anything atm. I think it might be coming from the sockets.
If by that you mean the fused connection unit (FCU) yes, however if you mean a consumer unit likely no.
So shall I just remove the plug of the extension and connect the 3 wires from the extention cable to the FCU. Would that be OK?
Thank u so much guys its done now.
Appreciate all your advice ! Works like a charm !
