I had an EURO 46 alarm with ARC monitoring. But due to increasing costs proposed by our provider (£37), its getting a bit much.
If i was to leave the our provider, is there anything i need to consider doing on the alarm or would everything continue to work as bells only with the current setup?
Or would it likely be the case that the alarm causes faults or alerts as its not longer connected to the ARC based on the current configured setup? i.e. i need another installer to re-config things correctly for bells only.
This i assume leads to the issues of not having the relevant engineer code. Is there an option to factory reset the panel to restore the engineer code (obviously everything connected would have to be re-programmed).
Would that be my only option?
Cheers,
hy
Cheers,
hy
