Hi, I've read a few helpful posts on here regarding these two issues.
A posting in 2024, was regarding a sensible upgrade path to a Euro version10 by swapping the PCB over and adding a digi wifi model for app use of arming / disarming / activation reports etc? Only problem is, now the Euro 46 v10 is discontinued isn't it?
Our system is bell only but the previous installer has put engineer only restore on tampers and we had to remove a PIR sensor for redec and plastering. I have read a few posts on powering down the unit which I can do, but haven't yet for fear of having an alarm sounding for hours.
I can remove the box cover an remove the battery lead. But will the bell sounder still work off it's own battery?
I don't know if I've got the sequence rigght but I'm putting together from other threads.. Is this right? o
Or please PM if you don't what to publish and I'll remove this part of post.
I do have user codes and the manager code but not the engineer code and it is not the default. Tks
open box cover.
tamper alarm sounds, disarm system with key tag.
Remove panel - battery backup connection
Turn off consumer isolator
Restore power
Hold down yes key for long time
Enter engineer area
open box cover.
Restore power
Enter engineer area
