Hi all, looking to get a bit of advice on what to do with this stop tap and hose area. I'm looking at replacing the stop tap as it needs a washer change as it doesn't completely shut off when i need it to. So i will get a 25mm to 15mm type. Also looking at installing a loo directly under this as well, so i'm thinking an equal tee is needed. I would like to get rid of the flexy hose? Guessing it's there as there is zero movement at each end to get rigid pipes in? So what are my options?
