Those are often bogged down by your BS as you are doing now.threads with significant "Nutjob" content tend to get bogged-down with irrelevant BS.
Not even worth it on commercial vehicle (lorry) engines.Yes you can send off an oil sample for testing, but on a small engine like a Mini, it'll probably cost about the same as changing the oil anyway. On ships, with several hundred gallons of engine oil, it's routine to do oil condition monitoring because the cost of the test is minuscule compared to the cost of the oil change
Try it in the rain, that might be a help for you if you’re spraying water.The biggest problem I found was the wind out in the open. It will absolutely disrupt painting.
Do you know a place selling waterborne paint? I tried search but nothing came up immediately that would sell a mix-according-to-reg. Waterborne paint should be sprayable in rain.Try it in the rain, that might be a help for you if you’re spraying water.
Where? America ?For back street bodyshops who use expensive lawyers, look what a bum deal you are giving to customers. It's pretty apparent where all the VOC paints are going.
No, local back street bodyshops. They continue to use VOC primers and VOC clear coats. So, they are the biggest buyers of VOC paints.Where? America ?
Which USA site?So why quote a usa site
The 1 you took your quote from and used it to suggest its what happens in uk.Which USA site?
So, because it is a USA site, the info is wrong?The 1 you took your quote from and used it to suggest its what happens in uk.
You did know you were on a usa site ?
It doesn't mean bodyshops use the same paint, dohSo, because it is a USA site, the info is wrong?
What paint would they be using? The place I got my base coat sample sells internationally. If not USA, where else would they be selling to at stupid prices?It doesn't mean bodyshops use the same paint, doh
