IP Rating requirement for Garage/Workshop Consumer Unit
24 Aug 2012
Bedfordshire
Hi, I'm looking to have mains installed in a detached brick built garage which will primarily be a workshop. I have had a couple of sparks in to quote and they have specified different CU's with different IP ratings. So, question for the sparks on here; Is there a specified requirement for the IP rating for electrics (particularly the CU) in a garage or workshop?
Well this is the list of rates where doyou think it needs to be?
My assumption is IP4 unless your workshop activities include pressure washer.
The minimum is IP4X on the top surface and IP2XC on all other surfaces. What have they quoted?
Those IP ratings refer to any holes etc that may have been made for cables etc. Assuming your garage is waterproof, and you aren't planning to spray water everywhere, then no specific IP rating is necessary. ie no need for a weathertight/weatherproof enclosure.
Unless they are claiming you need an IP rated CU, it may be a case of the CUs they propose to use have IP ratings even though such is not actually required for the application. As others have said, if it's not being used in a situation where such is required, there is no need for an IP rated CU.
A bit like a car salesman stating a new car can travel at 135mph even though the driver intends to drive at no more than 70mph
Unless they are claiming you need an IP rated CU ...
It may seem a bit pedantic, but it makes me shiver a bit, and makes me wonder whether some might get confused as a result, when I see people talking about "IP rated" items ...
... every electrical item under the sun has (or could be given) an IP rating (hence is "IP rated"), even if that rating is IP00 (no protection against anything). When (like it your post) people talk about "IP-rated items", what they obviously mean is 'having an IP rating at least as high as some (unstated)level" - but some people might not understand that, and might think that an item with any IP rating (no matter how 'loiw' a rating) is suitable for their purpose.
I would possibly say a case could be made for 5/4 or even 6/4 given that workshop activity could produce a lot of dust.
That's why I asked the question of what the regs require in either a garage or workshop environment. I would, I guess have to go for whichever is higher.
... it's a bit like the way a good few marketing/advertising people are using the word "quality" these days. It's quite common in things like TV ads to hear people say things like "It is a QUALITY product", with a lot of emphasis on the word "quality".
... but, I ask myself, what sort of "quality" are they talking about? I obviously know what they are trying to say, but in addition to things like "good quality" and "excellent quality", there are also other possibilities such as "poor quality" and "awful quality" :-)
Thanks, I don't have access at the moment but I think they both exceeded that.
I think you can be reassured, since it would be ridiculous for anyone to manufacture (and sell in the UK, or most other places) a CU which did not meet those minimum requirements, since it could never be compliant with UK regulations.
I understand where you are coming from but I'm asking "what" the IP rating is required to be, not "IF" it has one.
Assuming purchased from a reputable source. I have had a look on eBay and there are definitely some shady ones on there at ridiculously cheap prices. I doubt they are compliant with many regs.
