Hi all not been here for a while!
I'm just quoting a job.. Wiring for stables/tack room fed from old agricultural shed/garage building down the lane. This building is fed from the house.
Stables will be 2 circuits so i can use the BG IP rated garage unit which is compliant with amendment 3.
The Shed/garage building is the issue. Currently has 2 way insulated garage CU feeding socket and sewage plant. I need to add 3 additional circuits in a new CU. The building is technically dry but CU is positioned as such that it could be exposed to some splashes/damp walls/condensation. I can't seem to find any larger IP rated amendment 3 CU's. Wholesalers just show me the old hager insulated ones! Am i looking at a metal enclosure or has someone found another product that fits the bill. The client has specified that they would like everything to be IP rated as well so no lashing it in and doing a runner!!
Cheers all
Cheers all
