After refitting my bath (removed in a bid to stop rodents entering from next door); I realised I had forgotten to incorporate any junction in the waste for a condensate pipe - my current boiler is non-condensing and lives in a cupboard at the end of the bath.
The bath waste is 50mm solvent weld and dives below the floorboards, before immediately turning 90 degrees and running beside the joist to an outside stack.
Access is a little tight...
Unfortunately, access to the basin, or toilet waste would be even more problematic.
I could cut out a section of board to make better access, pry apart the bend and try and fit a solvent weld t, but I wondered if:
1) is it appropriate for a condensate pipe to join here in the first place?
and
2) Does anyone have any better ideas for a junction? - or do I remove the bath again, or even just leave it to the RGI who fits my next boiler!
Thanks!
and
Thanks!
