What is the name of the wooden wedge blocks that hold up guttering on older houses?
28 Apr 2024
My house has wooden wedges rather than plastic brackets to hold up the guttering. Do you know what these wedges are called and where I can buy them?
no expert here
but wedges can only ever follow the cement lines between bricks and as guttering needs a fall so not following the brick course at all so a bodge
also guttering needs lateral support as well as vertical so again not good
Here are photos of examples of what I'm referring to
They look like carpented / wooden wedge-shaped blocks, but I don't know what they're called.
ahh ok not what i thought
extension off floor/roof timbers perhaps ??
A joiner can make them up for you or take one into a joiners workshop and ask them to make copies.
I had two corbels fall off, but don't remember this happening. I believe the guttering was good when I first moved into our home. I need to get scaffolding up and get a bracket put up to hoist the guttering where it sags ever so slightly. A roofer added one bracket already, but couldn't get to the sag because of sloping ground. The guttering has a square (not round) profile when you look along its length. What sort of bracket would be best to use for this? Also, do corbels have a mechanism where they screw into the guttering as well as the wall/facias to stop the guttering from sliding away from the roof/wall?
