I have a MacGregor strimmer.
I have a recurring issue where it will work for about 1 min and eventually the line unravels.
I suspect I am not installing it correctly.
Here’s how I install it. The line fed into those notches like so
I put the line through the holes in the strimmer, place the cap on and cut lines to size.
This appears to be the correct method but after a very small amount of use it does this very abruptly.
I removed the cap - it doesn’t come off, the line unravels.
It appears the line comes out of those notches every time but they are definately in place when it goes in.
Any ideas what I’m getting wrong here?
Thank you
Thank you
