- Joined
- 21 May 2024
- Messages
- 3
- Reaction score
- 0
- Country
I've recently tried to flush my heating system and inadvertently managed to block the microbore pipes and boiler in the process. At least I had my immersion heater I thought. I have unfortunately found out that the immersion wasn't working either. My Dad brought around his electrical tester and we found that the immersion heater is working fine, however there is no continuity between the consumer unit and the point at which the wires meet with the switch in the airing cupboard. As a temporary measure I've put a plug on the immersion heater cable and plug it into a socket just outside the airing cupboard. The plug does however run hot after 30 mins as its only 13amp. With the unsightly wire as well coming out the door I do want to get it wired up properly again asap. I cannot work out what the issue is as if there is a break in the cables to the consumer unit wouldn't the RCD have tripped in the consumer unit, which it hasn't.
