- Joined
- 20 May 2021
- Messages
- 120
- Reaction score
- 1
- Country
Coming along nicely so far....
But not sure how to improve the lighting. I have a light switch going to one light bulb fitting already in the loft . I need two lights.
I think the new light fitting can be daisy chained from the last light fixture or a new wire for the new light can be taken from the loft light switch box. Both of these options require sticking two wires into small a pendant light connections or the light switch box connections - which is not ideal and fiddly in a dark loft.
Is there a way I can take the wire from the light switch - split it into two and then connect it to different light fitting so I can have two lights?
Is it possible to do the below - or does it HAVE to be daisy chained from the previous light or come from the light switch box?
And if its possible, what Connector will allow the live, neutral and earth to easily and cheaply be split off into two?
This - with the two wires coming out of it of one coming in?
https://www.screwfix.com/p/wago-24a-light-junction-box-39-x-95-x-29mm-grey/8423F
Or can I use something like this t-box?
https://www.screwfix.com/p/tower-3-way-20mm-tee-box-black/82706
And which wago connectors are best? 24a or less? Know the types I need to buy that are small and would fit into the above cases? Twisting the wires together is not not ideal and t-boxes with the connections built in are a pain to wire in the dark as well.
https://www.amazon.co.uk/WAGO-221-2411-Terminal-Conductor-Connector/dp/B077QJ3G5B
