- Joined
- 25 Jul 2022
- Messages
- 17,879
- Reaction score
- 1,500
- Country
Not what the evidence showsWe can safely say that the person who likes to make lies up is you.
To a price that more can afford, you mean?Again who will build and buy these homes that will reduce in value
I didnt realise immigration was the only thing that decided where a country sits on the overton windowI think your view of the nordics is a little dated.
In Sweden for example you will find anti immigration is high on the agenda.
A non denial - noted, I will leave it there and not pursue it again.I support capitalism because it is the only model that works
every Western country is pretty much a capitalist country, based on private enterprise, the difference is that some countries have more state control for fairer wealth distribution and safety net for the poor, whereas some countries do not (UK and USA)
I like the Scandinavian model of capitalism
Marxism, socialist, communism are great ideas but nobody has found a way to organise society that way
By the way Aveatry, life is a bit more nuanced than "if you criticise the Conservatives you must be a Marxist"
maybe you should try debating with more nuance
False argument again.Let me help…with the apparent objective.
We advocate the building of thousands...millions of homes so that the bottom falls out of the market
Again who will buy a house that is going to be worth less?
How will they obtain a mortgage on this depreciating asset ?
And who is going to invest money to buy land and build this house that people are afraid to buy ?
Binary view againI didnt realise immigration was the only thing that decided where a country sits on the overton window
So using your logic houses couldnt have been built in the 1970s when houses were more affordableAgain who will build and buy these homes that will reduce in value
Bottom falling out the market doesn't mean worthless to all. It means its worth less to investors.
Lots of people will buy if they can get a mortgage/afford
Who said that?You’d borrow money to knowingly put yourself in negative equity?
I can believe that. But most people aren’t as stupid
Did someone build millions of homes in the 70s to cause the bottom of the market to fall out.So using your logic houses couldnt have been built in the 1970s when houses were more affordable
Income to house price ratio more than doubles since the 70s
Even when adjusting for inflation, today’s homebuyers have by far the toughest financial task when it comes to housing affordability.
No. But a lack of houses built since then has done what to prices?Did someone build millions of homes in the 70s to cause the bottom of the market to fall out.
Do you understand what is meant to cause the bottom to fall out?Who said that?
Oh the forum idiot.
Why do you make things up? Easier to argue against?
Did someone destroy some houses? The same ratio of home ownership existed then as it does today.No. But a lack of houses built since then has done what to prices?
Who said it should fall overnight, or for ever.Do you understand what is meant to cause the bottom to fall out?
Who is going to buy a house during this process?
Today your home is worth £300k you have £100k tomorrow it’s worth £200k. Do you think the bank will let you off the loan.
